Water in the front diff
Old Aug 28, 2004 | 12:47 AM
ydopen's Avatar
Default Water in the front diff
I am getting water in the front diff., more than usual. When I had the front drive axle out the water and oil ran out, it did'nt do that on the other side when I replaced a torn boot. I noticed the outer seal was torn, is that my problem, or is there another seal on the inside that I need to replace?
Old Aug 28, 2004 | 10:24 PM
ydopen's Avatar
Anyone?
Old Aug 28, 2004 | 10:33 PM
MooseUnit's Avatar
nope, ive had no problem with water in my diff. Maybe bolts are loose or somethen i dunno. Try taken it back to the dealer after u get water in your diff.
Old Aug 28, 2004 | 10:39 PM
redbruteforce's Avatar
If one of the seals is torn you shoul replace it, if the tear starts to get bigger it will allow more than water to get in, the last thing you want is mud inside you differetial grinding away on your gears
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
RticKwad
Jul 21, 2015 03:00 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
tporath
Jul 11, 2015 12:31 PM
