Mojave 250 shift shaft
Old Aug 29, 2004 | 05:03 PM
jfisher304's Avatar
Default Mojave 250 shift shaft
I just picked up a 2001 250 Mojave for cheap, but the shift shaft is all messed up. the idiot owner before me welded that shifter to the shaft and now the shaft is breaking. Will I need to split the cases to replace it, or can it be done by just pulling the right side cover?
Old Aug 29, 2004 | 05:45 PM
rolsmojave3's Avatar
just the right side cover
Old Aug 29, 2004 | 06:06 PM
jfisher304's Avatar
Thanks! That's what I was hoping for.
Old Aug 29, 2004 | 09:25 PM
MojaveMoron250's Avatar
If you can get the shifter off all you have to do is take the right side cover off, the foot peg, kicker and water pump. Then you should be able to see what you have to do. Make sure you order a water pump gasket with the shaft and the clutch cover gasket. If you have trouble I have done it a few times so just give me a hollar.
Old Aug 30, 2004 | 12:31 AM
jfisher304's Avatar
Ok, thanks for the heads up on the water pump gasket. I have changed the shift shafts on other bikes, so I'm sure I can get it, just wanted to make sure. Thanks for the help.
Chris142's Avatar
Ya it's easy. You also must remove the clutch which is easy.
Order your parts now....I had to wait like 3 weeks to get mine when I ordered them.
Old Aug 30, 2004 | 12:35 AM
jfisher304's Avatar
I gues I got lucky on parts, the local Kawasaki shop had a shaft in stock........now I'll probably have to wait three weeks for the gasket..lol
Old Aug 30, 2004 | 10:02 AM
kwackermann's Avatar
... Glad to hear everything went well. The things some folks do to their quads-- oughtta call DCFS on'em! And welcome to the mojave brotherhood.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
