engine braking system
Old Sep 19, 2004 | 10:02 AM
randynj700's Avatar
Default engine braking system
Ive had my 700p for about a month, after a real bad stuck in the mud the EBC does not engage while going down steep hills, It worked really well prior to being stuck, any help is much appreciated.
Old Sep 19, 2004 | 10:56 AM
deerchooper's Avatar
hello randynj700, welcome to the forums.
check the fuses under your seat. your kebc fuse may be blown. also check to see if you have any mud or dirt in the kebc plug, if so clean and use dielectric grease to seal from water.
__________________
02 650p
see pictures for mods
Old Sep 19, 2004 | 11:51 AM
randynj700's Avatar
Thanks for the welcome. where is the kebc located?
Old Sep 19, 2004 | 02:31 PM
Kawi650's Avatar
the Kebc is a little round thing on top of your clutch, but the fuse for the kebec is under the seat. It is the thing that rattles when you shut your machine off, if you still hear it rattle then your fuse is ok. I also would recommend that you check your gear adjustment becuase that's the main problem for going down steep hills. Try low range. Also it is possible your belt could need a adjustment.
Old Sep 20, 2004 | 12:42 AM
kawiyowee's Avatar
It's time for you to check your motor mounts anyway, and I have heard that loose mounting bolts will interfere with engine braking. Also, look for cracked mounts as a precaution.
Checking motor mount bolts is a regular maintenance item for a lot of guys, because they sometimes are shipped untorqued, or they can loosen up by vibrating on rocky trails, etc. Never had a problem with mine though. Going to wash it tomorrow and also check bolts and mounts. Good luck.
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
rcappie4
Jul 10, 2015 04:54 PM
MNatv89
Jul 7, 2015 11:36 AM
