LIft effect on CV joints? (RINCON)
Old Oct 20, 2004 | 02:20 PM
Broadhead's Avatar
Default LIft effect on CV joints? (RINCON)
Any input on how likely I am to break my CV joints if I put a lift on? Right now my tires are stock but I'll probably go with 589's when replacement time rolls around. I was wondering how the angle affects the wear on the joints. Thanks.
Old Oct 20, 2004 | 05:39 PM
maddog56's Avatar
Well it depends on the height of the lift and the resulting drive angles, but just like in any other type of vehicle, the wear and strain will be faster and more severe. The higher you go, the worse it gets. I would suggest that unless your riding area or style necessitates 27"+ tires that you refrain from installing them for the best possible reliability.
I usually just put on whatever size the stock suspension setup can accept. That way my joints dont wear much more and my handling is impacted as little as possible.
QuadRiders
Oct 22, 2015 04:13 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
89Lt250r
Sep 7, 2015 07:53 PM
Cantbuytime
Aug 16, 2015 09:13 PM
toonces
Aug 13, 2015 12:40 PM
