Another new Brute force Problem - help please
Old Nov 4, 2004 | 01:21 PM
2005BF750's Avatar
Default Another new Brute force Problem - help please
I just picked my Brute Force up from having the needle installed and the a-arm fixed but now the engine braking noise that it makes after you shut off the bike won't stop. it just keeps making the noise about every 5 seconds. I had to pull the fuse to make it stop. any ideas on this one? ANYONE? I think this is the same engine braking stuff that's on the Prairie isn't it?
Old Nov 12, 2004 | 04:16 PM
2005BF750's Avatar
216 views and not one dang reply? gee thanks lol the dealer is stumped too. replaced the actuator motor and it did not help.
Old Nov 12, 2004 | 07:42 PM
goldbug's Avatar
Take the belt cover off and check to see if it might have been "parkrd" wrong, then follow the proper way to set it.. Maybe it will work right... Dealers DO make mistakes, but are hard to get to admit it...
Old Nov 12, 2004 | 09:30 PM
Kawi650's Avatar
I'm wondering if you have any other electrial components that are hooked up to your bike directly to your battery. I had my Fan override grounded out on my 650 and it made the KBEC to keep running after it was shut off but it wasn't 5 seconds appart. Kind weird how it is 5 seconds a part, I can see a continuos noise but 5 seconds appart? Sounds like it's not getting the KBEC in the propper spot when you shut it off and it continues to try. Do you hear it move the KBEC when you first shut it off? does the noise change after the first noise you hear when you shut it off? Maybe check to see if there's a drain on you battery when the machine is off. Any weird noises when the engine off but key on?
Old Nov 12, 2004 | 09:37 PM
2005BF750's Avatar
yeah, it sounds normal but then it just keeps doing the last little spurt of the motor every 5 seconds. dealer is trying the "main brain" module next. I have a winch direct to the battery but it works fine, properly grounded.
Old Nov 13, 2004 | 02:14 AM
Mudcon's Avatar
i havent heard of that?
Old Nov 13, 2004 | 05:58 AM
2005BF750's Avatar
I found one other thread about it
http://forums.atvconnection.com/mess...did/417000.cfm
Old Nov 13, 2004 | 12:27 PM
Kawi650's Avatar
I heard of 2 others CDIs going and in both cases the fuse blew first.
Old Nov 14, 2004 | 08:44 AM
piski's Avatar
justa shot in the dark...but none of the pins in the KEBC connector have pushed out and aren't making a good connection by chance ???
Old Nov 14, 2004 | 11:55 AM
2005BF750's Avatar
rode it this weekend with the fuse out, it's just like a Polaris, if you bump the throttle while descending it will keep the engine engaged. at some point in time though, the indicator started flashing from 2wd to 4wd so I guess it has yet another problem.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
