P700 owners
Old Nov 17, 2004 | 08:09 PM
BCNUCS's Avatar
Default P700 owners
Just got my 04 P700. I was just wondering if the stock prarie can normally pull the front wheels off the ground from a stand still. I am able to after I hit about 5 miles an hour, but it seems a little sluggish from a stand still. Other than that this quad has got all you want and then some.
Old Nov 17, 2004 | 09:09 PM
jpsdiving's Avatar
Default P700 owners
That is the way they come from the dealer, timing retarded, I have a Dyna CDI. There are other models of CDI's that are out there for your quad. Any Aftermarket CDI will help you on bottom end. That would be a good start. good luck.
Old Nov 17, 2004 | 10:31 PM
grownmancrying's Avatar
Default P700 owners
I have a DG 3 ($140.00) and my 04 P700 will stand on end ... you had better be holding on!!!!!!!!!!!!!!
Old Nov 17, 2004 | 10:36 PM
cookerwon's Avatar
Default P700 owners
when you install a dg3 do you have to rejet?
Old Nov 18, 2004 | 07:54 AM
skooter525's Avatar
Default P700 owners
I agree with Grownman, ya better be holding on if you install that module, and No rejetting needed
Old Nov 18, 2004 | 09:16 AM
turbojosh's Avatar
Default P700 owners
They have a dg5 that is better supposedly than the dg3 for the same price 140.00 and with a flywheel key for 20.00 dollars you should have a fast 4x4.
Old Nov 22, 2004 | 10:13 AM
turbojosh's Avatar
Default P700 owners
Do you have any pictures of these car climbs i would like to see some.
Old Nov 22, 2004 | 12:56 PM
Vengence's Avatar
Default P700 owners
Mine would it in low in stock trim... But now with the mods I've done, even in high gear, no-pulling required I can stand it on the rack!! Just Love my P700!!! Now if I can just figure out a way to mount a turbo, I'm in heaven!! hehehe
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
