1987 Forutrax 250x Help Needed
Old Nov 27, 2004 | 12:18 PM
jstracing's Avatar
Default 1987 Forutrax 250x Help Needed
I need ideas from people who know these quads. I fire it up and ride it about 500 feet and it dies. The exhaust gets extremely hot quick. When it cools down you can start it right back up. My thoughts are a bad valve but I have been told electrical, cam, or carb. The guy I bought it form in early spring said it needs the carb gone through but it rode so fine through the summer?? Have you got any ideas or ever had this happen??
Old Nov 27, 2004 | 12:35 PM
hondaguy2's Avatar
I would say it is the carb, it may be jetted too rich causing it to run hot.
Old Nov 27, 2004 | 03:14 PM
WISTECH's Avatar
Check your fuel filter.
Old Dec 12, 2004 | 05:45 PM
atvnatcparts's Avatar
SOUNDS LIKE THE CDI ON THE SIDE OF THE HEAD IS NOT TIMED RIGHT .
Old Dec 12, 2004 | 07:03 PM
WISTECH's Avatar
The 250x doesnt have an adjustable pulse generator like the older atvs did.
Old Dec 12, 2004 | 08:54 PM
dzzy's Avatar
Also check your fuel tank vent hose and cap to make sure they aren't obstructed. You may want to check your gas for water conamination too, since it's been around freezing lately. Bring a spare known good plug with you on your test ride, and check for spark immediately when it dies. If it has spark, you can eliminate the ignition as being the problem.
Old Dec 19, 2004 | 12:20 AM
cezar21's Avatar
sonds like its running lean to me and just needs to be rejeted when it gets colder outside the air gets thiner
Old Dec 19, 2004 | 12:55 AM
CapnMorgan's Avatar
Sounds lean to me too.
when it gets cold outside the air gets denser and has higher oxygen content therfore causing an unballanced fuel/air ratio (more air than fuel) hence a lean condition.
If you run it lean too long you will have a valve problem.
Old Dec 19, 2004 | 11:21 PM
WISTECH's Avatar
If he had a jetting problem I seriously doubt he would make it 5 feet not 500. And colder air is not thinner it is denser.
sara durrant
Jul 6, 2015 05:32 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
