plow causing front end to sag
Old Jan 22, 2005 | 06:47 PM
LT230Sracer's Avatar
Default plow causing front end to sag
I have a '96 Trailboss 250 and when i have the plow on it the front end sags so the plow is only 2-3" off the ground. What can i do to fix this?
Old Jan 22, 2005 | 07:51 PM
highwayman's Avatar
Go to the dealer or an aftermarket shop and get some rubber spacers for the front springs
Old Jan 22, 2005 | 10:04 PM
elkbow's Avatar
you can order them directly from polaris:
rubber spacers
Old Jan 22, 2005 | 10:05 PM
new2atv's Avatar
I purchased 2 pair of coil spring spacers from Polaris because my Xplorer was doing the same thing. They're $15.99 a pair and they made a big difference. When I don't have the plow on, I don't even realize they're there. Check out my photos, I have a picture of them installed. It took about 15 minutes to do and it was pretty simple.
Old Jan 22, 2005 | 10:26 PM
elkbow's Avatar
Good pics Matt, always helps to show what you mean. I think the ideal setup is the way you did, put two on each side...I have the same thing...don't leave them in though...
Old Jan 23, 2005 | 12:24 PM
davenh's Avatar
I have a question on these spacers. I bought a set and installed them in my 04.5 700 w/ the Glacier plow. They seemed to go in too easy. Even with the plow lifted, the spring does not compress onto the spacer. I can spin them around and pull them in and out even with the plow lifted. Is this right? I was expecting them to limit the front end sag and be a paint ot install, but it seems they only work when you hit a big bump or something.
Old Jan 23, 2005 | 11:27 PM
new2atv's Avatar
Thanks Elkbow. I was planning on taking them out in the spring once the snow is gone and putting them back in next fall. Have you had any problems with leaving them in? Just curious.
Old Jan 24, 2005 | 01:23 AM
elkbow's Avatar
I don't leave mine in and don't have any problems putting them in and taking them out, but only did it once since my machine is new. Not like I get much snow here, I bought the Glacier setup because of the 20% off they had online. Its not a problem to leave them in for the winter, but if you plan on doing alot of off-roading, then you'll lose your suspension on the front end, which is handling, etc.....stiff ride on the front.
Davenh....they should fit fairly snug, shouldn't be loose.
dave
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
tporath
Jul 11, 2015 12:31 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
cornermike
Jul 8, 2015 11:44 PM
