Automatic clutch
Old Feb 14, 2005 | 04:03 PM
BGun's Avatar
Default Automatic clutch
i have a little 85 honda trx125 and the automatic clutch is slipping, i was wondering if there is an adjustment for this or do i have to replace parts?
Old Feb 14, 2005 | 09:30 PM
Polaris500HO4x4's Avatar
you probablly need new springs and friction plates... has the clutch ever been replaced? probablly in need of a change
Old Feb 15, 2005 | 03:44 AM
KNOWSALOT's Avatar
The Facility
BGun,
There is an adjustment on the right side engine case. The adjustment is found on the "bulge" of that side case.
Just remove the rubber protector [if it's still there over all these years] and it's directly underneath it.
Loosen the locknut and turn the screw in the center of it counterclockwise until you feel resistance on it. Then turn it back clockwise 1/4 turn and then hold it still while tightening the locknut back down. That's it. If you still have a problem afterwards, you will need to tear into that left crankcase and see which parts are worn.
Good luck
Patrick
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
