400L not going into hi and Reverse
my 94 400L will not go into hi - reverse but does great in low. when going into hi or reverse it does not make a single sound. it not the rod hand. the lever on top the transmission moves but nothing. also the light sensers R-N do not light up. could it have any thing to do with that little box the shifer is on. could that keep it from shiffting. any information will help alot. does any one know a good web site for transmissions with prices. thanks
Does it feel like it is actually going into gear or what?? I know those linkages can get out of whack sometimes, and need adjustment. Or try unhooking your shifter from the gearcase, and use a wrench and see if that helps to get it in gear, if so......then you need adjustment........if not......you probably have tranny issues........maybe a bent fork or something.
Try taking the lever off the top of the tranny and shifting it with vise grips.If that makes it click in gear then the bellcrank(the lever )is stripped.It has to move solid with no play.Have you checked the oil and guts in the shifter box?
when you move the lever i can see the arm on top of the tany it moves smooth. i can hear somthing move in their but it doest do a thing its really odd could it be that box the shifer handle is on is there fuses or wires that would not alow it to work
Just try taking the lever off and see how it does.If it works the trouble is in the shifter if it doesnt work it is time to pull the tranny and put in new shift forks.
The wires that go to that box for the shifter are just for the N and R lights to work. They will not effect the shifting at all.
Like they said, if the small lever on top of the tranny moves and it doesn't shift, then it could be stripped where it connects, or its an internal problem.
Mine does this after lots of plowing in the winter.
You need to adjust the shifter rod.
Take off the plastic on the right side of the machine, move the shifter from high to reverse to identify which shifter rod, back off the locking nuts on each end, then spin the rod to lengthen it slightly.
This may take a couple of tries to get both high and reverse to engage, retighten the lock nuts, and go tear up some turf!!!
