scrambler wont start
Old Mar 11, 2005 | 08:52 PM
BrokeYJ's Avatar
Default scrambler wont start
I bought a 99 scrambler 500 tuesday. It started fine both times I went to look at it, when I unloaded it and even wednesday. Yesterday it wouldnt start. It turns over fine and will catch for about a second and then dies. This is my first atv so I hope I am just overlooking something simple.
Old Mar 11, 2005 | 09:52 PM
2manytoys's Avatar
I know this may be a stupid question but did you turn the gas on, is there gas in it, and did you use the choke? Also check the plug and or put in a new plug. It may even be flooded from transporting it.
Old Mar 11, 2005 | 10:00 PM
MrToys's Avatar
You have a bad ignition switch. It is quite common on 99-02 scrambler. Water gets in the back. You can verify this buy removing the switch and taking it apart and cleaning the contacts.
Old Mar 13, 2005 | 06:32 PM
BrokeYJ's Avatar
Thanks guys, It was just flooded. Dried it out and it started fine. The ignition switch was having a contact issue as well, the back of the switch wasnt clipped in well so I fixed that too while I was in there. Took it to the woods today for the first ride and I am definately hooked.
polaris scrambler00
Jun 20, 2015 08:49 AM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
