Starter Squeeling
Old Sep 25, 2000 | 12:23 PM
Loyal's Avatar
Went for a run this weekend and did some mudding in stuff very similar to chocolate cake mix, really slippery stuff.
Anyway, when the mud finished playing with us (yea the mud won . . . this time) I noticed a "squeeling" sound coming from my Xplorer 400 when starting. Sounded like the starting motor and would only happen as the bike was starting and stop when she was running.
When I got home and cleaned her up the sound did not occur. Would it be possible that the "soup" we enclountered caused the problem?
Or should I start digging within the motor?
Old Sep 25, 2000 | 01:27 PM
Thor's Avatar
Did you drain the recoil starter housing?
Also you may want to grease up the starter drive and flywheel. Polaris makes a special grease for this which should elminate your squeeling problem.
Old Sep 26, 2000 | 10:36 PM
will's Avatar
I would take the recoil starter housing off and clean the bendix take out the drain plugs and spray some wd-40 in it. Also put some kind of silicone around the pull start and around the housing
Old Sep 27, 2000 | 07:13 AM
Loyal's Avatar
When I remove the recoil starter, will the spring "pop out" and cuse all sorts of grief.
I have had flashbacks to my 1983 Trimoto 125 when I was replacing the pull cord and the spring in the housing decided that it did not like where it was living and came out. 2 weeks later I had it recoiled.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
