05 rancher AT oil leak??
Old Mar 21, 2005 | 08:08 PM
tynes's Avatar
Default 05 rancher AT oil leak??
saw today that i'm leaking oil at the cover for the pull rope. Seems like ive heard others with the same problem but cant find it w/ the search. Still under warranty but wondered if the problem would returen after putting another seal in it. Guess i will let them fix it.
Old Mar 21, 2005 | 08:50 PM
Gimpster's Avatar
A seal will fix the problem only if the crankshaft does not have excessive run-out.
A good dealer will check the crank end run-out and note it in the work order plus replace the seal.
If they don't try to figure out what caused the seal to go bad, and your crank is out of spec, it will start leaking again.
----- Gimpster -----
exmotocrosser
Sep 13, 2019 06:12 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Clint Russell
Sep 25, 2015 03:20 PM
wrencher82
Sep 24, 2015 03:39 PM
