Noise in rear of Recon
Old Apr 6, 2005 | 11:36 AM
RABDAB's Avatar
Default Noise in rear of Recon
I have a noise in the rear of my 02 Recon. You here it while making turns. I turned the motor off and drifted down hill, it makes noise when you turn, more then straight. I thinks it's the axle bearing. My main question is can I continue to ride or fix immediately, we have a trip planned this weekend and I'm not sure if I can get if fixed by then.
Old Apr 6, 2005 | 05:13 PM
RideRedOrStayHome's Avatar
if its the bearing you should be able to ride for a while just dont be hard on it mine 300 as the same prob
Old Apr 6, 2005 | 05:22 PM
RABDAB's Avatar
Ride Red, you think I could put another 100 - 150 miles on it. It just started making the noise. Everyone I talked to seems to think it's the bearings. I'm sure you ride yours pretty hard ! If not what's the sence in riding.........
Old Apr 6, 2005 | 05:41 PM
Live2Mud's Avatar
if it is just the bearings i aint that hard to replace them may take a couple of hours at the most, better safe than sorry.
Old Apr 6, 2005 | 05:51 PM
ye better safe that sorry but if he wants to ride this weekend hes not going to have the parts by the weekend unless the dealer has them is stock only thing you want to worry about is the bearing throwing things out of alinement achewing up the ring gear and pion gear
Old Apr 6, 2005 | 06:03 PM
Live2Mud's Avatar
ridered is right but maybe you could find a dealer that would overnight them
Old Apr 7, 2005 | 03:40 AM
confusedbuyer's Avatar
can't you just take the ID and OD measurements and get them from any bearing shop or parts supplier. that's how i buy all my bearings, and they're cheaper than atv dealer.OR, look close at old bearing and take the number off of it, then get it from anywhere.
Old Apr 8, 2005 | 08:56 PM
be28936's Avatar
That happened to my brothers recon to. Didn't need to replace the bearing though. All we did was pop that golden cover off and greased the bearing with a bearing greaser. All that is is a needled that goes in the beaing and has an end on it that a grease gun can go on. We greased it and it fixed it. We haven't had a problem with it since then.
Old Apr 10, 2005 | 12:58 AM
hondarulesinnc's Avatar
I rode mine until everything fell out, I mean the bearings were compleatly gone, I would not recomend riding it that long but it took about 6 months from begining to the end so you have a good while to go. Mine started out as a pop when going over bumps and humps and progressivly got worse, so if that is the case it is deffinatly the bearings, but one weekend of riding is not going to hurt a thing.
greg74
Sep 10, 2019 03:03 PM
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
