buying 400ex front shocks tomorrow/ which to get and where?
Old Sep 29, 2000 | 03:02 AM
400exman's Avatar
I am ordering new front shocks tomorrow and am leaning toward triple rate works with res. for $489 from magic racing, they stock them and said they could set them up for me at 245 lbs. I DON'T want to wait for a set of shocks that are on backorder and don't want to spend over $700 any suggestions? Maybe ohlins? (the gold resoviors on the shocks plain look BAD!)
Old Sep 29, 2000 | 01:02 PM
Trx440's Avatar
If you are not racing then don't get the rez's. You will not be able to tell the difference. I raced a set of triples w/o rez'z last year and could only get them to fade in practice. And I weigh 245 also. Make sure you weigh yourself with ALL your gear on, in my case it adds @20lbs.
Next year, if the funds are in order, you can have TCS or Legacy rebuild yor Works and add rez's for @ $400. That's what I did and the difference is amazing. Either of these shops will not use the stock Works rez's so it's the same price for Works with or witout rez'z. Plus I believe you can still get Works triples w/o rez for $295. I think the last post I saw was from Shoc Connection.
If I were rating the shocks I've ridden [on a 400ex] from a scale of 1-10 it would go like this: Stock=2, Works triples=6, Ohlins=7, PEP=8, TCS=9, Good Luck
toonces
Oct 16, 2019 12:11 PM
DTroyer01
Jul 3, 2015 07:34 AM
Mphillips
Jul 2, 2015 07:20 PM
blaze_master
May 26, 2015 11:18 AM
250rCanCan
Sep 20, 1999 07:48 PM
