400ex clicks and doesnt start
Old Apr 19, 2005 | 12:06 AM
Ish416's Avatar
Default 400ex clicks and doesnt start
My 400ex decided to be a pain and stop starting for me. I push the start button and I get a click from the starter solenoid and nothing else. I know the battery, starter and fuses are good, I think it's a grounding issue or something being loose. Anyone have this problem before and know where a good place to start would be? Thanks
Old Apr 19, 2005 | 09:02 PM
TractorPacker's Avatar
Do you have a balloon?
Sorry to tell you but, it's probably the relay. I just bought one from the bike shop and it cost about $60. My 400ex did the exact same thing.
Old Apr 19, 2005 | 09:03 PM
Try crossing the relay with a wrench and see if it goes then.
Old Apr 19, 2005 | 09:35 PM
Gimpster's Avatar
If the solenoid clicks it is normally good, I think the starter brushes are bad.
----- Gimpster -----
Old Apr 19, 2005 | 10:10 PM
Ross250x's Avatar
this happened to my old 400 before u do anything make sure u first check the connections on the relay and check the connections on the battery it may just need a cleaning.
Old Apr 19, 2005 | 10:23 PM
TrailBlazerguy250's Avatar
i think its just a bad battery connection , happens on my buddies 400ex all the time
Old Jul 12, 2024 | 10:10 PM
Tiredandabused's Avatar
My Honda 400ex I hit start button and one single click confirmed the solenoid Mount back near my battery and bike won't start anybody help me out . If I jump the two terminals on them solenoid I should have the button on or off. And if this switches in the off position what will it d
Old Jul 13, 2024 | 02:50 AM
As you can see from above posts, lots of things it could be, so test and find out. Firstly check all earth and thick pos wires are clean and tight. Next get a 12v incandescent test light (LEDs are useless for testing). Put one lead on solenoid to starter wire, other to earth. Switch ign on, press start button. If solenoid clicks but lamp doesn't light, faulty solenoid, if lamp does light but starter doesn't turn, faulty starter, usually brushes. Faulty brushes get a bit intermittent, so jumping the terminals isn't the best way to test, brushes could decide to work when you jump the terminals, so you think it is a solenoid fault. A test light shows the true fault.
Mkp
Mar 28, 2020 03:50 AM
nature violator
Jul 3, 2015 08:40 PM
jayking232003
Jun 9, 2015 02:54 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
