What PSI do you run your vampires???
Old Jan 14, 2000 | 08:26 PM
mattsibley's Avatar
Please list the amount of air pressure, the width and hieght of the tire, and the quad you have it on. I have a honda 300 4x4 with 24X9-11 vampires on front with 15psi for easy steering. On the back I have 25X12-11 vamps with 10 psi, for a little smoother ride and a slight bit more traction than the front.
Matt Sibley
1999 Honda 300 4x4 Vampires, Lift Kit, 2500lb WARN winch
Old Jan 14, 2000 | 10:48 PM
BIGBEAR4x4's Avatar
I got 25X9.5X12 on my bear on the stock rims with 20psi in all 4 tires....with tha stock rims and same tire width it makes the front tires just a hair taller than the real tires
Old Jan 15, 2000 | 12:37 PM
SwampMonster's Avatar
Hey matt!
It depends on what type of riding I'm doing. I prefer to keep mine down to about 4 or 5 psi for most mud applications. I prefer this because the more pressure you put in the tires the less "contact space" you have with the ground. I've found that running them at low pressure (factory recommended) they have more bite in the mud because they have more tread in the mud.
On the other hand if I know I'm going into some deep stuff (usually watery also) then I pump up to between 15 and 20 psi for the extra flotation.
"LOCK 'EM AND LEAVE 'EM!!!"
SwampMonster
1999 Foreman 450S Locked, Lifted, Vamped, Snorkeled, and did I mention widened? (wheel spacers)
mattsibley
23
May 24, 2007 09:56 PM
ROMAN
Feb 8, 2001 07:46 AM
Andy Bassham
Apr 21, 2000 01:50 AM
TxDoc2
Feb 5, 2000 03:05 AM
muskeg
Feb 2, 2000 11:44 AM
