E-TON IGNITION
Old May 4, 2005 | 12:10 PM
kotoole552's Avatar
Default E-TON IGNITION
Does anyone know who much an ignition for an e-ton viper 90 woul cost? Thanks
Old May 4, 2005 | 12:54 PM
newnick's Avatar
What part do you need?
Old May 4, 2005 | 05:04 PM
kotoole552's Avatar
A friend of mine said i needed a new ignition because it takes a while before it will start. The brake light wont come on untill about 2 mins after i turn the keys. He told me i needed a new ignition.
Old May 4, 2005 | 05:53 PM
LT80's Avatar
LT80 Expert
We need more info. [img]i/expressions/face-icon-small-smile.gif[/img]
Your buddy "may" be correct, but I'm not convinced the ignition is the problem.
Please explain in detail what you are doing and what it does/doesn't do. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 4, 2005 | 06:03 PM
newnick's Avatar
Your brake light comes on when you pull the lever in. Does it take two minutes after you pull the lever in? On our Eton we had the key switch go bad from corrosion. I took it of and pulled it apart and cleaned it real well and put some dielectric grease in it. Then after I put it back together I siliconed it to hold it together. The brake switch may also be the problem, it's on the left handle bar. One way to check the key switch is to disconnect it and jump the connector on the quad.
Old May 4, 2005 | 10:22 PM
eton150's Avatar
swap out the ign. that should work.
Old May 4, 2005 | 11:09 PM
LT80's Avatar
LT80 Expert
I'm thinking same as newnick.
Cleaning connections and dielectic grease is alot cheaper than swapping ignitions.
Old May 5, 2005 | 09:14 AM
kotoole552's Avatar
Yeah thats it i will get it apart and cleaned and put some dielectric grease on it as soon as possible. Thanks for the help[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
