Oily pull cord?
Old Jun 13, 2005 | 08:02 PM
lusty's Avatar
Default Oily pull cord?
I have been using my pull cord quite a bit lately and I noticed that the cord is quite oily with a black/grey fluid. I have not noticed this before in any of the Yamaha's I have owned previously. Is this normal? BL
Old Jun 14, 2005 | 10:47 PM
EAB's Avatar
EAB
I had the same problem on my 400. Like polarifreak said, changed the seal and no further problem.
Old Jun 15, 2005 | 07:32 PM
lusty's Avatar
How difficult a job is it to replace the crank seal? BL
Old Jun 19, 2005 | 04:51 PM
EAB's Avatar
EAB
Not hard if you are somewhat handy. The only thing that held me up was the flywheel which is on there tight. Use a good harmonic balancer puller and lube all of the friction points on the puller before you begin. I have an air compressor and impact gun which made it easy. There is a 'star' nut in there, but all you have to do is to mark its position before you begin then use a hammer and punch to loosen it. Then tighten it the same way and line up the marks.
Oh , also have the flywheel lightened while your in there for a little better throttle response[img]i/expressions/face-icon-small-smile.gif[/img]
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
awer1968
Sep 8, 2015 11:02 AM
