Clutches, Clutches, Clutches????
Old Oct 10, 2000 | 12:02 PM
Sanddude's Avatar
I was wondering what everyone out there in the rest of the world(anywhere but I-Da-Ho) thought of Clutches? I am replacing my Clutch and my basket. For a Basket I was gonna go with a Hinson and as far as a Clutch i wasn't sure. Some say go for a stock Suzuki, but last I checked after market was meant to be better than stock, so any input anyone can assist me with would be greatly appriciated.
Old Oct 10, 2000 | 03:20 PM
retro's Avatar
I put a Vesera in my 250R and it works great wih my Hinson basket.
ERIC
Old Oct 11, 2000 | 09:36 AM
dunerash's Avatar
i have a stock basket steels and plates with cr-500 springs this set-up seems to work well for me,in my opinion a lot of aftermarket stuff is not as good as stock.
Old Oct 11, 2000 | 01:12 PM
Jennifer's Avatar
I haven't heard many folks using a Veserah clutch, Barnett's are ok. I have a EBC Dirt Racer clutch kit in mine. Works pretty well in my banshee. A little costly but i've had it in there for over 2 years. In case your wondering yes I ride it pretty hard, got to to stay ahead.
Old Oct 11, 2000 | 06:09 PM
Mike Frey's Avatar
I bet the CR500 springs made a huge difference in clutch pull?
Why did you choose different springs? I've heard that you use springs from the next biggest displacement machine when you modify your engine. For example, use CR250 springs in a modified CR125.
Old Oct 11, 2000 | 06:31 PM
jwhite's Avatar
I also use stock fiber and metal plates with CR500 springs in my Honda 250R.
The real reason I use CR500's...That's what Gary Denton used to use, I figured it must be a decent setup because his machine was probably pushing a lot more HP than mine.
I have had great luck with this setup. I went to aftermarket clutch springs and it burned up my clutch almost instantly. I dont think all aftermarket parts are better than stock, this being one of those exceptions.
Old Oct 11, 2000 | 07:41 PM
250R_Man's Avatar
I had CR500 springs on a Factory Honda 250R I bought from a racer in 1988. I never replaced the clutch ever.
I've done one even better. I went to Home Depot and bought 5, 3 cent washers and put them under the springs on both or my 250R's. My 85 still has original plates (from 85...stock plates)and my 86 has Veshra plates. Both work great. I ride it in the sand, dirt, ice, etc. If it doesn't slip in the sand, then it'll hold in any other contition.
The "weight" of the clutch, meaning how hard it is to pull in, is not bad. I've never noticed much of a difference.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
