suggestions wanted
Old Oct 10, 2000 | 01:18 PM
hillclimbing4kix's Avatar
i am trying to save some money and do the service on my trailboss this time tired of spending $90 to have it greased and the oil changed but how do i reach the grease fitting on the left side bushing on the swing arm cant reach it seems like the cluch casing is in the way thats the only one i cant get to and i dont want to let it go with out grease
Old Oct 10, 2000 | 01:23 PM
MagnumMudMan's Avatar
hillclimbing
I get to this bushing from the rear. I sit with my legs under the machine and lean into rear area. I have long enough arms to get the grease gun on it. It helps also that I have a pistol type grease gun. I can keep one hand on the fitting and one to operate the gun. Try using a stiffer hose if you can't reach it. Post another message if this didn't make any sense. BTW, It helps to have a good treble light up in there also, to see the fitting.
Old Oct 10, 2000 | 05:01 PM
DaBoss's Avatar
I have a pretty stiff hose and just push it up onto the fitting. Sometimes it doesn't go on right and I squirt some grease out, then I just try again.
For anyone wondering, I am talking about greasing the quad... although this could describe other aspects of my life.
Old Oct 11, 2000 | 10:16 AM
Farmr123's Avatar
On mine, the zerk is pointed towards the right. Reach from the right side by the rear sprocket, across the swingarm & I can reach right up to the zerk. Works best laying on your side behind the machine & with a pistol grip gun with the longest hose you can find.
Farmr
Old Oct 11, 2000 | 03:45 PM
Xplor's Avatar
Can't you just turn the zerk? Mine are all pointed towards the rear. With the big grease gun I can reach them just fine...
Old Oct 11, 2000 | 08:29 PM
waynaferd's Avatar
I reach around the chainside behind the shock, and can reach it pretty easily if you long armed, it also helps to set the backend up on a crate or bucket
Old Oct 12, 2000 | 09:44 AM
Farmr123's Avatar
It is actually easier (for me anyway) to reach from the right across the swingarm behind the rear shock than it is to try and fit my hand around from the left behind the belt cover. If I EVER have the fender off for any reason, I am going to extend the zerk. Implement dealers have small diameter high pressure hoses with ends that match zerk threads. Unscrew the zerk, screw in the hose, put the zerk in the other end. Can get them from about 6" up to maybe 24" long. They even have a metal sleeve on the 'loose' end so you can cable clamp the end down & not squash the actual hose. It isn't on my 'gotta do' list, but it IS on my 'maybe someday if I get to it' list. I would think the hose would be well protected by the frame & such.
Farmr
Old Oct 12, 2000 | 10:08 AM
Loyal's Avatar
I put a floor jack under my Xplorer and jack the whole bike up. It allows a little more room to get under bike from behind.
Get a pistol grip gun grease gun also.
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
cSchwartz
Jul 12, 2015 07:42 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
Chocobamofo
Jul 10, 2015 07:46 PM
