Clutch Upgrades
Old Jun 20, 2005 | 10:12 PM
Geebooen's Avatar
Default Clutch Upgrades
I tring to up grade my 02 Honda rancher & 03 Honda rubicon clutches,the instrution sheet says I need honda clutch tool #07933-hb3000a for rancher & #07zmc-hn2a100 for rubicon,do I needs these tools to remove clutch or are there any other ways to remove them.Any help would be great, went to service honda.com but the can't get the tools
Old Jun 21, 2005 | 02:54 PM
pat89's Avatar
I used a Snap-On three jaw puller to remove mine. The clutch puller usually is not necessary. If the puller will not easily remove it, then invest in the expensive tool as you do not want to warp the clutch housing. If you are replacing the springs with performance springs, invest in a drum brake spring tool as the new springs are much stiffer and more difficult to reinstall. Double check that the Rancher does not have a nut stake before removing the crank nut. You will need an impact to remove it. To re-torque the crank nut you can hold it in place by wedging a screwdriver, carefully, between the transmission gears.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
