96 SP 400 Limiter Problems
Old Jun 22, 2005 | 10:37 AM
catchinwalleyes's Avatar
Default 96 SP 400 Limitor Problems
My 400 will not stay running. I have replaced the speed limiter, but that did not make a difference. If I disconnect the single yellow wire on the speed limitor it will run, but when it's in 4WD it just doesn't have the power. It will not rev up. Even in 2WD it takes a long time to get up to speed. In reverse it works a lot better. Any ideas? Any help is appreciated.
Thanks
Old Jun 22, 2005 | 06:36 PM
ftwflh's Avatar
Default 96 SP 400 Limiter Problems
Unplug the black wire on the limiter.
Old Jun 24, 2005 | 10:58 AM
I left the yellow disconnected and disconnected the black one as well and it 's seems to be running a lot better.
Thanks,
Old Jul 5, 2005 | 11:18 AM
2WD now seems fine, as well as 4WD in reverse, but in 4WD going forward still does not work.
Thanks,
Steve
Old Jul 5, 2005 | 06:07 PM
ftwflh's Avatar
Does the 4x4 AWD light come on when you put it in gear or push the button?
Old Jul 6, 2005 | 09:17 AM
The AWD light does come on when it is enabled.
Old Jul 6, 2005 | 05:58 PM
ftwflh's Avatar
Do you have a manual?If so it shows how to check the switches.You need to check the switch in the shifter.
Old Jul 7, 2005 | 09:35 AM
I have the manual. I will check it out tonight.
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Ramman1
Jun 16, 2016 09:07 PM
hondarider1234
Jul 21, 2015 11:53 PM
