New Gates belt HELP !!
Old Jun 24, 2005 | 12:26 PM
scarabrick's Avatar
Default New Gates belt HELP !!
Just got in 2 new gates belts for my 05 scrambler 500. It cost me less than $20 bucks each and I was wondering if using a Gates verses Polaris belt if I would have to SHIM anything or just put it on Number side facing away from engine?
Thanks in advance,
RIck
Old Jun 25, 2005 | 02:13 AM
scarabrick's Avatar
ANYONE! help a brother out. Do I have to shim to put on a new gates belt? I'm going to replace my original Polaris belt.
Thanks
Old Jun 25, 2005 | 02:21 AM
duneaholic's Avatar
You shouldn't have to shim anything. Just put in on and go. The only time you would need to shim anything is if your clutch was out of alignment. If it was in good alignment when you had the Polaris belt on then I should say then you are good to go.
Old Jun 25, 2005 | 12:44 PM
jimk72's Avatar
The gates should be a direct replacement if you got the right model. I got a deal on a dayco and a gates and tried them both. They both seemed alot better than stock so I put the dayco in and have the gates for a backup.
Old Jun 25, 2005 | 02:57 PM
Backinthesaddleagain's Avatar
DON'T DO IT!!!!!
Old Jun 25, 2005 | 02:58 PM
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 27, 2005 | 02:55 AM
jimmypsp700's Avatar
Thanks in advance,
RIck
I think the wording should be right side up as you put it on from the left side of the quad. Top of letters inward.
Jim
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Irishman301
Sep 23, 2015 01:47 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
