Clutch Kit
Old Jul 10, 2005 | 12:21 AM
POLARISSportsman500HO's Avatar
Default Clutch Kit
Im thinking about a clutch kit for my sp 500 ho. Any recomendations? Also how hard are they to install? Will I need to do anything besides a clutch kit for it to run right? Any help is appreciated.
Thanks
Ty
Old Jul 10, 2005 | 12:28 AM
SPORTSMAN70003's Avatar
Default Clutch Kit
I like the heel clicker clutch kits they work real good. You can go to www.heelclicker.com and it shows the instructions.
Old Jul 10, 2005 | 01:00 AM
DGScrambler400's Avatar
Default Clutch Kit
you could also give Rick at RCR a call and he will set you up. his prices and service cant be beat
Old Jul 10, 2005 | 03:47 AM
scrambler123's Avatar
Default Clutch Kit
theyre not very hard to install at all. no you wont need anyhting else for it to run right.
Old Jul 10, 2005 | 01:25 PM
RickRitter's Avatar
Default Clutch Kit
My best recomendation for your 500 is a Dalton Industries DBW500 . The kit contains Primary and secondary clutch springs and the Dalton Industries billet weights .
There is also a kit called a DP500A . It works better for running at higher speeds but most poeple will prefer the DBW500 .
I am the oldest Dalton ATV clutch distributor in the USA , and we stock it all . It is more costly for us to purchase these parts from out of the country , but we feel it is worth the cost . Dalton clutch kits and tuning parts are the best available for the big utilty quads .
You can get great detailed information at the following website .
http://www.daltonindustries.com/atv/clutchkits.htm
Rick Ritter
Old Jul 11, 2005 | 09:26 AM
NBsportsman's Avatar
Default Clutch Kit
If you don't want to lay down the big $$ for a kit the Dalton secondary spring #DPSS-B made a huge improvement in my 500. Better back shifting and holds lower gear longer with out losing any top end for under $40. Try this link........ >>>>DALTON SPRINGS<<<<
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
