what is the problem
Old Jul 12, 2005 | 01:29 PM
04atp500's Avatar
Default what is the problem
i have a 2004 atp 500 and it will not turn over unless i push on the throttle a little bit and then when i put it into gear if i dont give it more gas it dies and if i give it more gas it takes off what could be the problem
Old Jul 12, 2005 | 01:39 PM
polarisbob's Avatar
it nay be your ETC on the throttle it may be bad or you have TOO much slack in the cable.
Bob
Old Jul 12, 2005 | 03:21 PM
04atp500's Avatar
how much are those
Old Jul 12, 2005 | 03:52 PM
emeraldisleatv's Avatar
I guess you'r cabel can be adjusted at the carb or at the throttle. Eithre that or you could fiddel witht the screw on the carb that adjusts the revs of the engine. Can't remember the proper name for it. Although I think it still should turn over.
Old Jul 12, 2005 | 04:52 PM
polarisbob's Avatar
if there is to much play in the cable it wont even turn over but 04atp500 see if you have any play in the throttle cable that is coming out of the throttle you should have about a milimeter of play in the thumb lever.And if that doesnt work take it to a dealer and they will check it out and if its bad they will replace for free if its under waranty or they will tell you how much it is to replace it.
Bob
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
