500 sportsman poor power
Old Aug 3, 2005 | 11:18 PM
B4THFNSTRTS's Avatar
Default 500 sportsman poor power
i have a 2001 sportsman starts right up and idles great as soon as you try to accelerate it backfires and has no power any help would be apreciated[img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 3, 2005 | 11:47 PM
Jayblazer's Avatar
maybe a broken weight in the primary??
btw what does your name mean if you dont mind me asking??
Old Aug 4, 2005 | 12:37 AM
LittleBill's Avatar
Before The Fuc*en Noise Starts???
Old Aug 4, 2005 | 02:47 AM
polarisbear500's Avatar
sounds like you may have water getting sucked into the carb, check your airbox for water.
2nd- is your reverse override being pushed?
3rd- your reverse sensor may be bad- a way to check if the sensor is bad is go above 5 mph, and hit the reverse override button while in forward and if the engine spitting/sputtering clears up when you hit the button, the sensor on your tranny is prolly bad-also your reverse light is usually lit up while in forward when the sensor is bad
4th-maybe your camshaft is bad, causing it to idle fine, but when you gas on it in gear, it just doesn't have what it use too. hope this helps, PB500
Old Aug 4, 2005 | 08:17 AM
2c3's Avatar
2c3
someone posted about this problem a few weeks ago and they had a torn intake boot. if thats not it it might be a loose plug wire.
Old Aug 4, 2005 | 11:28 AM
NBsportsman's Avatar
Could bee the ETC switch out of adjustment causing your problem. Pop the cover off and see if the contacts are touching and adjust to fix.....
Old Aug 4, 2005 | 12:57 PM
NascarFan's Avatar
Don't forget the old worn out exhaust cam lobe. Hope that's not it. I would think if this is the case, it would have gotten worse over a period of time.
Old Aug 5, 2005 | 10:33 AM
Speedwerx's Avatar
Sounds like a bad cam to me But check carb and intake as well when taking it apart. This is a good time for an upgrade too while its apart.
Old Aug 7, 2005 | 01:39 PM
in replt to your email idont think that its a broken weight as it pops back througn the intake as soon as you try to accellerate
as for my name its be 4 the fun starts i dont no y it just works
Old Aug 14, 2005 | 04:23 PM
SupraForRaptor's Avatar
The problem is a dirty air filter,that simple,not trying to sound like I know it all. But I own a 500 sportsman and the exact same thing happend to mine and all I did was put a new air filter in. By the way how deep of water do you ride in????Because I ride 4 and a half foot deep water every day and have helpful tips for deeper water travel !! [img]i/expressions/face-icon-small-wink.gif[/img]
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
