99 scrambler again ???
Old Sep 10, 2005 | 08:11 PM
marksduramax's Avatar
Default 99 scrambler again ???
ok was ride the scramber i just bought and i climb a small hill and i got white smoke from the left side where the belt cover is... so i got it on flat land 2 wheel drive it jumps going forwards so i took that cover off and the belt looks new. i tryed drivin forwards agin and the belt moves but not a lot what could this be? i just had a new cam put in i have had this quad a week now. had nothing but problems so far. Please help. thanks
Old Sep 10, 2005 | 08:49 PM
ftwflh's Avatar
Take the secondary clutch apart and look.Sounds like you could have a bad clutch.
Old Sep 10, 2005 | 09:25 PM
wheres that at? how much dose that run in price ?
Old Sep 10, 2005 | 10:27 PM
ftwflh's Avatar
It is the big clutch in the cover.It has a snapring on the back to get it apart. Do you have a service manual for this bike?If not you need to get one.
Old Sep 10, 2005 | 11:59 PM
jimk72's Avatar
There is a good set of instruction in my pics. just save and print and use that.
Old Sep 11, 2005 | 12:05 AM
jimk72's Avatar
You also need to be more descriptive and clear about what is going on. It sounds to me like everything is fine? you give it gas it jumps going forward do it again and the belt moves, isn't that what it is supposed to do?
are you saying you can jump the quad going forward and the belt is moving?
Your best bet is to look everything over real close and make sure things are as they should be. You may just have something out of place or need to set your secondary or your not used to riding the quad itself.
Old Sep 11, 2005 | 12:21 AM
Ill cheek ever thing tomro thanks for the info on your page. let ya no but thanks again
Old Sep 11, 2005 | 12:43 AM
jimk72's Avatar
Anytime you get a used quad it is best to inspect everything very close, change all fluids and check all moving parts to be safe. If you see any zirks make shure you grease those too. You don't want to be going 60MPH and have your quad fall apart on you. I usualy do a full inspection before every ride. I only ride about 2-3 times a month so it is not that big of a deal. If you ride it alot just make sure you check things out atleast once a month. Things like tire lugs, chain tension, play in rear swingarm, ect...
Old Sep 11, 2005 | 12:52 AM
i have greased ever fitin i found cheek all that stuff out im planin on just use this quad for huntin it has 4 wheel drive my 400 ex dont i dont do to good hauling all my stuff to the woods when its wet and on a steep hill. i just hope i can get all the stuff fixed befor huntin season.
Old Sep 11, 2005 | 02:52 PM
Ok i just took the belt off cheek it out good. one side the side that faces out side is wore a little not bad. the end side looked fine. so i filped the belt around and road it its not jumpin so that means my belt is bad? or is both sides wear out the same?
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
