Wont start/ETC problem
Old Nov 18, 2005 | 01:38 PM
94sport400L's Avatar
Default Wont start/ETC problem
Got a 94 sport 400L that wont start. Started fine the other day. Re-routed the throttle cable and now it won't start. It fired up once but as soon as I gave it gas it died. Now it doesn't even sound like it wants to start. Did i mess something up with the ETC? How does the ETC work? Any help appreciated.
Thanks
Old Nov 18, 2005 | 05:36 PM
conig's Avatar
the etc is pretty straight forward. if the two contacts inside touch it closes a curcuit causeing a short and shutting down the motor. if you take the cover off the throttle make sure they are not touching.
another thing to do would be to unplug the ETC fron the throttle assembly just forward of the wire if the machine runs then the insides are touching. You can;t tighten down the screw inside the assembly all that much or the it has to be kibnda loose otherwise the ETC will touch and won;t disengage. the throttle may also get stuck.(I had this happen)
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
