330 CLUTCHING REPROT
Old Nov 26, 2005 | 11:20 PM
ftwflh's Avatar
Default 330 CLUTCHING REPROT
I did some testing with springs on my 330 today and here is how it went.
stock spring(blue/green) engagement rpm -1300 shiftout 5770
Polaris white engagment-1750 shiftout 5890
EPI pink engagment- 1550shiftout 5990
EPI pink w/Aaen blue secondary at 2-2 engagment 1550 shiftout 5950
This is just my comparison so take it as that.
Old Nov 26, 2005 | 11:42 PM
2manytoys's Avatar
ftwfth,
Like i said all along that the epi pink is the best setup for the 330. Although I do have a little different results. The pink engagement for me is around 1300 and shiftout with a secondary spring from a Trailblazer250 is @6100.
Old Nov 27, 2005 | 12:47 AM
ftwflh's Avatar
Lots of variables like tires and traction but it does give a good starting point for comparing.
Old Nov 27, 2005 | 01:02 AM
2manytoys's Avatar
Yes there is. Since I put on the bigger tires it did slow down a little but plenty more power than stock. I may do a gear change to get my top end back.
Old Nov 27, 2005 | 08:15 AM
kj330's Avatar
ya the epi pink helped out my atp 330 alot. i called erlandsonsports and they said something like, the only better thing than the epi pink, is to switch my clutches to a full roller clutch. i havent looked into it any more though.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
