Scrambler Tranny Leaking Oil
Old Dec 6, 2005 | 01:19 PM
EatsRiceBurners's Avatar
Default Scrambler Tranny Leaking Oil
My '02 Scrambler 4x4 is leaking quite a bit of oil when it sits out of the lower rear seam on the trans case where they join together. I think the kid that sold it might have hit a rock or something. Probably why he sold it. I keep it full before every ride. Do you think it is worth tearing into this winter to fix, it looks like a major? Could i drain the oil, brakeclean the seam and blue goo it? I do all or my own work, but splitting the trans case in half is a little intimidating.
Mark
Old Dec 6, 2005 | 01:29 PM
Bradracer18's Avatar
Its not too bad........I've done it about 10 times or so. You probably have a bad seal, gasket, or a crack in the tranny. All of which are common. I'd get it done now. If you have a clutch puller......I'd go at it. If you need to know how to do it say.....otherwise, get to tearing apart. If you don't have a good memory of how to put back together......use a camera.
Old Dec 6, 2005 | 01:49 PM
Whiteone's Avatar
I just had the same problem with my "00 scrambler 400. It was the gasket or lack of. It is pretty straight forward to remove. I didn't use the puller, I just pulled back the back belt cover. Its been a few months now with no problems.
Old Dec 6, 2005 | 06:02 PM
ftwflh's Avatar
The trannys dont have gaskets they call for useing silicon gasket (formagasket).And it is a rather simple job.Get you a clutch puller and a service manual.
Old Dec 6, 2005 | 06:47 PM
Jayblazer's Avatar
i would go for it better safe then sorry also while your in there you can inspect other parts for
wear "like the silent chain" ..
Old Dec 6, 2005 | 06:56 PM
ftwflh's Avatar
I thought it was a given that you change the chain out when you split the cases[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 6, 2005 | 07:01 PM
Jayblazer's Avatar
thats what i was getting at...lol...just incase.
Old Dec 6, 2005 | 08:27 PM
That is why I take the clutch off too(on a non concentric model anyway).....so I can check the swing arm bolts and bushings......and I change the chain and sprockets out usually too....and possibly the brake pads........
Old Dec 11, 2005 | 10:42 PM
tmzg29's Avatar
Just pull the case and inspect it for cracks. If it is ok then replace the silent chain and seals and put a good bead of silicone gasket sealer on it and you are good to go. I broke a drive chain and knocked a hole in my tranny. I had it out, rewelded and back in over a weekend. Not hard. I have pics in my profile of the patch work I did. Worked out great and saved me a bunch of money.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
wrencher82
Sep 24, 2015 03:39 PM
