Sportsman 500 4wd inop
Old Dec 11, 2005 | 05:31 PM
Sarge22's Avatar
Default Sportsman 500 4wd inop
I have a 2000 Sportsman 500 and the AWD quit working suddenly. The speedo also does not work. I have checked the fuses and all are good. Any input would be appreciated.
Sarge22
Old Dec 11, 2005 | 05:37 PM
SPORTSMAN70003's Avatar
Sounds like you need a new speedo. The speedo controls the AWD and when the speedo goes out so does the AWD.
Old Dec 11, 2005 | 08:41 PM
2manytoys's Avatar
Do you get power to the speedo but the needle just does not move? If everything else works but the needle does not move then most likely the hall effect sensor is bad. It is a sensor on the right front strut that gives the signal to the speedo. If this is bad the speedo wont work and neither will the awd. These go out alot more often than the speedo.
Old Dec 12, 2005 | 11:26 PM
Sarge22's Avatar
Thanks I will check for power there. The speedo did quit all at once, the needle does not move at all.
Sarge
Old Oct 28, 2006 | 08:38 PM
rnico's Avatar
Sarge22,
I have the exact same problems. Did you get yours fixed?? If so, what was the cure??
thanks,
rnico
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
