Rancher 400 sensor problems.
Old Jan 21, 2006 | 04:33 PM
Atvstevo1337's Avatar
Default Rancher 400 sensor problems.
We just replaced the sensor for the transmission because one of the seals was leaking oil and horribly messed it up. the problem is we dont know how to reset the new one ( or cpu) and untill we find out the esp flashes 3-4 times and wont shift out of first gear.
Old Feb 7, 2006 | 10:48 PM
slough's Avatar
hey bud . first . what sensor did u replace whats the name of it . and second if u type in rancher at at the advance search go to where it says rancher gear is select is blinking and read through the hole thing and at the bottom a guy told me how to erass touble codes and how to set the computer try this ok .
Old Feb 8, 2006 | 03:37 PM
1988TRX250R's Avatar
If you replaced the sensor on the lower left side of the motor, this is the angle sensor. When installing and angle sensor on the Rancher 400 and Rubicon, they need to be preloaded. If this is not done, the ECU will throw a trouble code and go into limp mode. Once the sensor is installed correctly, the ECU needs to be re-initalized for all sensors to be in sync. Even if not initalized immediately, you should be able to drive the machine w/ out it throwing a code right away. The procedure to initalize is too lenghty to type it out, but actually only takes a few minutes to perform it.
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
