Warrior Jetting Problem
Old Feb 5, 2006 | 06:26 PM
fastazzblaster's Avatar
Default Warrior Jetting Problem
I have a 2001 warrior, i just got a hmf slip on, air box lib removed. My problem is that im currently running a 145 main jet, and with choke on i pop and sputter, tryed smaller jets and bigger jets, im thinking its from the air screw, the parking brake it not on, and i am getting good fuel from everywhere, any suggestions????
Old Feb 5, 2006 | 06:53 PM
recon99's Avatar
Well, i'd expect it to run $hitty with the choke on. You should only need to use the choke for 10 seconds or less when the jetting is right.
If you didn't go up a size on the pilot jet try that. The stock jet is a 142.5, try a 145, that's what most will use. Start with the fuel screw 2 turns out from fully in.
Old Feb 5, 2006 | 07:08 PM
schwabm's Avatar
With Full Choke it runs good, with excellent throttle response
Old Feb 5, 2006 | 08:04 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
he should need a 45 pilot and a 147.5 main with his setup.. it's the same thing i am going to run.
Old Feb 5, 2006 | 09:06 PM
recon99's Avatar
Oh $hit I meant to say go up from a 42.5 pilot to a 45 pilot!
I'm still don't completely understand what the problem is though. When does it pop? Idle, half throttle, full throttle? And he says with the choke on. What does it do when the choke is off?
Old Feb 5, 2006 | 09:13 PM
Speedy2222's Avatar
if he is running it with the choke on it is gonna be bad for the quad... also.. when you remove the lid you have to go up 2 jet sizes on the main... if you run filter only and a slipon you need a 150
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
Captjay
Jul 23, 2015 12:33 PM
Reactant
Jul 16, 2015 10:29 PM
cSchwartz
Jul 9, 2015 02:43 PM
