Rancher 350ES Reverse
Old Feb 9, 2006 | 05:37 PM
cskin69's Avatar
Default Rancher 350ES Reverse
My friend has a 2001 Rancher 350ES 2x4 and his reverse has quit working with the Electronic Shift, it will go into reverse using the manual lever but will not when using the ES. Has anyone else had a problem with this or know what can be done to fix this?
Old Feb 9, 2006 | 05:49 PM
mykool61679's Avatar
might be the sensor ?
Old Feb 9, 2006 | 06:21 PM
LittleBill's Avatar
i can tell you how to exactly fix it,
there is a reverse switch on the es, which sits down below the pull start on the motor, it is a single wire, green if i remember correctly, pull this wire off the reverse sensor clean it and put it back on with dielectric grease, i had the exact same problem
Old Mar 8, 2006 | 02:39 PM
fairfax6000's Avatar
Little Bill is right. The reverse wire on the bottom of the engine looks alot like a small spark plug wire that goes into the engine. If it is broken, dirty, or wet you will not be able to shift into reverse.
Old Mar 14, 2006 | 02:09 PM
bal3wolf's Avatar
ya i had same thing happen to mine got knocked loose riding thru woods i pushed it back on tight and reverse came back
vandammages@gmail.com
Aug 20, 2020 11:50 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
