Replace clutch housing comp.on 2005 660 grizley
Old Feb 18, 2006 | 07:16 PM
THUMPER69's Avatar
Default Replace clutch housing comp.on 2005 660 grizley
Can anyone tell me the steps in replacing the clutch housing comp. The reason is that the treads on the shaft are striped off. I was abile to figure out how to take off the primary sheave and the belt ,but the secondary sheave is a bit confusing I can't figure out how to stop it from spinning so i can get the the nut off.Also I noticed a large spring behind the secondary. Is there any thing special i need to know abot that.For as the clutch housing goes it apears that a snap ring holds it on, is that correct are am I missing something?
Old Feb 18, 2006 | 08:29 PM
lafngas's Avatar
be very careful of that big nut with the spring behind it. the spring is under a lot of pressure. I am not sure what exactly you are asking about so I really can't help
Old Feb 20, 2006 | 03:23 PM
THUMPER69's Avatar
I'm trying to replace the shaft that the primary sheave sits on.I just wondering how to take every thing apart to replace the clutch housing shaft
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Shifts
Jul 3, 2015 07:59 AM
