SP 700 balljoints
Old Feb 21, 2006 | 01:42 AM
itstillruns's Avatar
Default SP 700 balljoints
Well, while changing my front brakes I noticed a HUGE movement in front struts. Now How do I get the toasted balljoints out? ) 04 700SP
Old May 4, 2007 | 09:14 PM
purepoisonrulz's Avatar
take the strutt off and put in a vice. then remove the two allen head screws that hold the safty plate on, put a peice of 2 inch pipe over the joint, use a peice of small steel that the threads of the ball joint will fit through and put the nut back on, tighten the nut and the joint will pull out
Old May 7, 2007 | 04:34 PM
liftedandgifted's Avatar
Even easier. after removing the allens heat the aluminum housing slightly and you can pull the old one out with a set of pliers, only because it is a little warm, and slightly heat the housing and put the new one in. It will push in easily.
jimk72
Aug 6, 2011 08:27 PM
cape kfx400
Feb 11, 2010 06:11 PM
Xplorer96
Oct 3, 2009 02:33 PM
Wormy400
Jul 29, 2008 02:49 PM
quadMXer70
Dec 30, 2002 09:19 PM
