gearing lt 80
Old Apr 22, 2006 | 11:09 PM
allstardj's Avatar
Default gearing lt 80
just got a 13 front and 27 rear new chain and chain tensioner what will this do to low end for starts
Old Apr 22, 2006 | 11:25 PM
2manytoys's Avatar
What is the stock gearing?
Old Apr 22, 2006 | 11:28 PM
allstardj's Avatar
front 10 rear 22 but not positive on the rear
Old Apr 22, 2006 | 11:33 PM
2manytoys's Avatar
Ok so its an newer lt 80 because the older ones came with 12/26 and the newer ones have 10/22. Now you have 13/27. Here is the gear ratios witht he different gear set ups.
13/27= 2:07
12/26=2:16
10/22=2:20
The 13/27 will give you the best top end and the 10/22 will give the best low end.
Old Apr 22, 2006 | 11:38 PM
allstardj's Avatar
thanks for help it is a 2005 lt 80 was looking for some more mid range power for corner speed also am having a power reed put in will this help
Old Apr 22, 2006 | 11:42 PM
2manytoys's Avatar
The 13/27 will give you more speed but you will lose bottom end. The power reed will help.
Old Apr 22, 2006 | 11:47 PM
allstardj's Avatar
what gear set up do you think would be the best tack is 1.3 miles with 2 long straights and the rest are normal straichts with jumps and turns
Old Apr 23, 2006 | 10:31 AM
LT80's Avatar
LT80 Expert
For that long of a track, and with a stock motor, you will need to gear up. Somewhere around 14-15-16 front sprockets.
A reed may help slightly.
You may consider shaving the head .030 and removing 2 of the 6 front clutch rollers. This will bump up the compression and allow the clutch to have a slightly higher stall speed.
Study up before you waste alot of $$$ for bolt on things that don't help. [img]i/expressions/face-icon-small-wink.gif[/img]
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
