Prairie Clutch after getting Wet
I rode the Blue **** Poker Run this Weekend and had a great time. About 2miles from the end of the ride there is a huge mud hole. I started playing around in this hole thats really more like a pond and made it through the shallow parts only a 1 1/2 foot deep. I even pulled out a Polaris Sportsman (suprise). On about the 5th time through in a different spot I hadn't been through before I submarined it up to the front rack. It was tilted at an angle so the air intake and exhaust stayed high and dry. Unfortunately The last time I had the Belt cover off I didn't put the gasket back in right so it leaked fairly bad. By the time I got a winch line to me It had filled up. Once I got out the belt was really slipping but I got it dryed out enogugh to finish the ride. Then I spent about an hour going through the clutch on sunday with a toothbrush and a bucket of water. Don't have it put back together yet but has anyone had problems with their clutches after getting them wet? I don't just mean water either there was a coating of mud on everthing in there. During this ride a grizzly and a rubicon got stuck in the same place also so I didn't feel bad.
Thanks,
Strings
2004 Kawasaki 360 Prairie 4X4
Full Skid Plates
Mud-Lites
Moose Hand Guards
1999 Honda 300EX
2004 Arctic Cat 250 4X4
1972 Ford Bronco
1993 Chevy 1 Ton
Detroit Diesel
Thanks,
Strings
Full Skid Plates
Mud-Lites
Moose Hand Guards
1999 Honda 300EX
1972 Ford Bronco
1993 Chevy 1 Ton
Detroit Diesel
I really cleaned that whole area out really well. So there shouldn't be much if any mud left in there. I also checked my belt and it looks pretty straight. One other thing I learned from this ride is that I want more responce out of my Prairie. So i'm going to put in a Black EPI Secondary Clutch Spring, TwinAir Filter, Dyno Jet Jet Kit, and A 6 degree advance timing key. I figured with all of this It should make that sluggich 360 a little more peppy.
Strings
Strings
Hey Strings, I have the same machine and I just installed the dynojet kit the other day. What a difference it made. Much better throttle response and more grunt in the low to mid range power. Not much difference in the top end though. I have a K&N filter coming soon, hope that helps also.
