LT80 Clutch
Old May 31, 2006 | 01:15 PM
imsquisht's Avatar
Default LT80 Clutch
I am trying to get to the clutch and I have all the bolts removed and it apears nothing holding it back but I can get the primary cover seperated.I have been tapping with a rubber mallet but it does not want to break the seal.
Does the oil injector pump need to be removed? Am i Not applying enough force? is there a secret I don't know?
Thanks
Steve
Old May 31, 2006 | 01:44 PM
Hymis's Avatar
Default LT80 Clutch
Hello, Make sure you got all the bolts off. I think you will need to remove the drain plug as well. It has a large phillips head. If the cover has never been removed it might be a little tight at first. You dont need to remove the oil pump. Just the bolts, foot pegs and the left rear tire to make the operation a little more easy.
Old May 31, 2006 | 04:28 PM
Quad4Fun's Avatar
Default LT80 Clutch
You do not need to remove the drain plug.
The hidden bolt is on the removable cover on the case.
Take the screw in the 3:00 position out (right side).
You still might have to tap it a little to get 'er out, but that should do it.
Good Luck.
Don't feel bad, took me forever to figure out that dang bolt the first time also [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 1, 2006 | 12:08 PM
LT80's Avatar
LT80 Expert
Default LT80 Clutch
buddieboy
Dec 9, 2016 05:50 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
