Warn 2500 problem
Old Jun 6, 2006 | 12:02 AM
Uinthas's Avatar
Default Warn 2500 problem
went to use my winch this weekened, & the "in" would not work on the rocker swith but the "out" did work, any idea of what might be the problem???
Old Jun 6, 2006 | 09:39 PM
Rattlebars's Avatar
Dirty contacts? Does the solonoid click? Try some contact cleaner.... might work...
Not too familiar with the switch you have tho.....
Old Jun 6, 2006 | 09:44 PM
Wildcountry's Avatar
I alos have problem with it but mine sparks when realed in and actually give you a small shock like it is gounded to the frame. But i have checked all wires and there is not a cut or anything on them what is going on. It is also not pulling as hard as it use to now with this problem.
Old Jun 7, 2006 | 02:28 PM
MNKawi's Avatar
Same think happened to me last year with the same winch. My relay is mounted under the battery, so it's subject to being dunked in water from time to time. The seal must have been bad on the relay because water got inside and it got fried. Luckily it was warrantied, but this is almost a $100 part. You should be able to check for voltage on the blue and yellow wires when you are trying to run your winch. Red should be hot, black ground, and when you push the in or out button you should have power to one of the other two wires. Mine only fried the "in". I put some silicone around the new relay so there is no way that water is getting in this time.
Old Jun 7, 2006 | 04:38 PM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
I have been reading these posts and still thinking about a new winch. I have a 2000 lb that never gave me any trouble yet, but it hasn't been used a whole lot.
Now for my new winch I am leaning towards a 3000 just for the lifetime warranty. With these parts being expensive and not real easy to get, wouldn't it be worth it......or not??
Sorry to ask questions on someone else's thread. I hope you get it working soon. Sounds like good info so far here.
Old Jun 7, 2006 | 05:28 PM
Rattlebars's Avatar
I had a different poblem. My winch chewed up the end case which is plastic (they all are as far as I can tell).
For details on this Click Here
Before I put it back together, I welded the internal nuts to the internal bracket because they were merely held in place by the plastic end caps and spun like nobody's business when rusted and corroded. Nearly impossible to disassemble the thing....
Old Jun 7, 2006 | 05:58 PM
MNKawi's Avatar
I did the exact same thing. Mine was only a year old and I wanted to install a fairlead roller but I had to disassemble the whole thing to get those nuts off. Just put a small spot weld on each and it will hold it fine. Roofer, if you are happy with your 2000 lb. winch, just stick with it. If it ain't broke....well you know.
Old Jun 7, 2006 | 06:30 PM
Roofer's Avatar
Thanks, but I'm not replacing the winch. I need a new one for my BF. The 2000 is staying on the prairie.
Cole Hadden
Jun 15, 2025 09:05 AM
toonces
Oct 19, 2015 02:21 AM
papahouse
Jul 28, 2015 12:42 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
cornermike
Jul 8, 2015 11:44 PM
