how to take apart a driven clutch?
Old Jul 15, 2006 | 08:19 PM
js380's Avatar
Default driven clutch help needed
1999 335 sportsman
i just had my local shop install new buttons and both bushings that go inside of the driven clutch.
i rode the atv for about 1 hr and it done fine until i got home and just before i pulled into my driveway
i oped up the throttle wide open and when i let off the throttle the atv held back as if it was in low range so
i tried to go top speed the atv would only go about 15 mph.so i took of the clutch cover and noticed the driven clutch
is stuck closed and will not open.any ideas on what has happened?also what do i need to take this clutch off and apart?i would like to check it out myself,if some one could send me instuctions from a shop manual that would be great.
Old Jul 15, 2006 | 09:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you just had the shop put in the buttons i would take it back to them and let them fix it since sounds like they messed it up. sounds like there is no preload on the clutch or the spring is messed up. all you need is a set of snap ring pliers. but i would at least call the shop and tell them what is going on so they can make it right.
Old Jul 15, 2006 | 11:19 PM
js380's Avatar
Default how to take apart a driven clutch?
i will check with the shop stendori thanks.
does anyone have directions from a shop manual on how to disasemble a
driven clutch on a 1999 335 sportsman?also does anyone know where i can purchase
a used driven clutch in good condition for a cheap price?
thanks in advance.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
