Clutch Springs
Old Jul 19, 2006 | 12:58 PM
MuddyScrambler400's Avatar
Default Clutch Springs
I am looking to change clutch springs but I don't want to have to buy a helix and weights. I just want to change springs to give me more lowend. What would be the best springs, where should I buy them, and how much do they cost.
Old Jul 19, 2006 | 01:12 PM
cbmboy's Avatar
call rick ritter.... explain to him your set up and what you want out of it... he will recommend the best spring for you... he is one of the best, hands down
the springs usually cost around $25 i believe... but call rick ritter and he will set you up
Old Jul 20, 2006 | 01:37 AM
scramblered's Avatar
engine will not have more bottom power,but a proper spring change will give more 'usable' power regarding what is the set-up righ now and clutch states,,you'll need probably a softer rate spring in the first number,but that will give you a lower engagement rpm.
follow what stated above...
Old Sep 23, 2006 | 03:15 PM
What springs do you guys have in yours?
Old Sep 23, 2006 | 06:12 PM
ftwflh's Avatar
If you are running a stock pipe go with either a Polaris green or a Dalton black/white primary spring to replace the stock one.
Old Sep 24, 2006 | 04:29 PM
Can you tell a difference after you switch springs because it seems cheap for what people say what it does.
Old Sep 24, 2006 | 05:33 PM
ftwflh's Avatar
It does make a noticable improvement
Old Sep 24, 2006 | 05:37 PM
i use high stressed sled spring in the primary only,it give me the response i'm wanting from it and can keep the engagement in the lower rev for most riding.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
