Are 27" MudLite XTR's Right for Rincon??
Old Jul 23, 2006 | 08:30 PM
highwayrider09's Avatar
Default Are 27" MudLite XTR's Right for Rincon??
I am about to get a 2006 Rincon and I was just wondering if 27" MudLite XTR's with 14" rims are right for a Rincon. How much power and speed will I lose? Can they make the Rincon better? I'll appreciate any advice. Thanks.
Old Jul 23, 2006 | 09:59 PM
ForemanDan's Avatar
They will fit. They will rub a little when turning on a downhill slope. They will make it loose a lot of power.
I suggest a smaller size. Also there are better tires out there.
Old Jul 23, 2006 | 11:27 PM
2manytoys's Avatar
No reason to go bigger. Just stay with stock size or go up 1 size and get a more agressive tire. My rincon does better with an agressive stock tire than my friends Sp700 with 27" tires. Its better to have the power available with the right size tire than have a bigger size tire and not have the power needed to spin them. Going up to a 27" tire only gains about 1" of clearance. This will not do much in the real world of mudding but take all your power.
Old Jul 24, 2006 | 01:34 PM
MikeM's Avatar
Rincon already has radials, so you can get a more aggressive tread, but there are enough utility radial designs out now that I'd never go back to a bias ply, no matter what I wanted to ride (mud, trail, etc). There's a reason they aren't using bias ply tires on cars (or much of anything) anymore.
Old Jul 24, 2006 | 05:21 PM
cluby's Avatar
Ok what kinda trails do you ride on? Do you want 27 for the extra ground clearance or?
May want to think about getting the high lifter gear reduction kit, helps with bigger tires. Need to take into a dealer to have done kit replaces stock gears inside motor with lower gearing.
How about looking into the mxr radial tires.
Nondem
Feb 22, 2020 12:20 PM
neilbedwell
Nov 10, 2018 11:02 AM
Norseman
Apr 7, 2002 07:50 PM
Recondude
Nov 13, 2001 08:24 PM
YZGUY
Sep 21, 2001 10:12 AM
