04 YFZ 450 Problem
Old Jul 29, 2006 | 03:49 AM
rc3's Avatar
rc3
Default 04 YFZ 450 Problem
Bike wont start using the ignition switch, when it is running the high beams and the brake/tail light does not work, but the low beam lights do work. this is a 2004 YFZ 450, what do you think the problem could be!
Old Jul 29, 2006 | 04:08 AM
JLsparky7's Avatar
Battery could be toast, hook it up to a charger and see how it acts.
Old Jul 29, 2006 | 02:39 PM
rc3's Avatar
rc3
it is probally a battery, and not the stator, is that what you are thinking!, if you cross the wires and make it fire, it just wont fire using the switch! and when it is is running the low beams work but not the high, and not the tail lights!
Old Jul 29, 2006 | 02:55 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Will it PULL START??????????? when running are the low beam light dim at idle and do they brighten up upon throttling the quad ??????????
put an OHM/VOLT meter on your battery NOT running. It should read 13 volts.........
put the same meter on it running and it should read 14.3 volts running (throttle it up).......
Check ALL your electrical connections take them apart and clean ANY debris (WD-40 works very well) in any of the plugs. Use dilelectric grease and snap them together GOOD AND SNUG........
You could have a stator problem........ [img]i/expressions/face-icon-small-sad.gif[/img]
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
