warrior problems pls HELP!
Old Aug 3, 2006 | 02:05 PM
ZapooMafoo's Avatar
Default warrior problems pls HELP!
right after a long ride, it was running perfect and the next day I changed the axle bearing and when I went to start it up and it made the clicking sound like the battery was dead. I charged it and it started right up. but it only lasted a day or 2. after that it made the clicking sound again and I would have to charge it again [img]i/expressions/face-icon-small-sad.gif[/img]. do I have to get a new battery?
Thanks for all replies.
Old Aug 3, 2006 | 02:26 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Most likely it is the battery either that or a new starter is needed. Take your battery some where that does testing and get it tested than you'll know what you need to get.
Old Aug 3, 2006 | 02:29 PM
ZapooMafoo's Avatar
When I bought the warrior in 2005 they just replaced the starter so I think I need a new battery.
Old Aug 3, 2006 | 11:52 PM
ZapooMafoo's Avatar
any more suggestions would be greatly appreciated.
Thanks.
Old Aug 4, 2006 | 12:02 AM
2phast4u's Avatar
iv had the same problem w/ my warrior i tried replacing the battery and it worked for a few days so finally i found out it was the starter solenoid its not an very expensive part $30 at most its the little solinoid on the rear left side of the atv check it out when u start it put your finger on the solenoid if u feel it vibrating thats deff your prob
Old Aug 5, 2006 | 11:43 AM
YamahaRider8998's Avatar
is that sylenmoid thing the thick wire thing that goes to the positve side of the battery. CAuse i have the same problem with the clicking and when i press the start button i feel it vibrate. any help would be apprecitraed.
steve
Old Aug 5, 2006 | 12:32 PM
bump
Old Aug 5, 2006 | 01:07 PM
2phast4u's Avatar
yes the solinod would be your problem
Old Aug 6, 2006 | 06:05 PM
ZapooMafoo's Avatar
Is it the thick wire or the little cylinder thing because the cylinder is what vibrates for me.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
