48 Lectron
Old Aug 14, 2006 | 08:43 PM
DragonDJ11's Avatar
Default 48 Lectron
Ok, a little help. I am under the impression, that the 48 Lectron requires the extended thumb throttle. Does that come with a whole new throttle housing, or is it just a longer thumb throw in general. If it is the latter, it would not change how far it pulls the cable, it would just lessen the pull on the thumb.....Explain please
Old Aug 14, 2006 | 08:45 PM
FatHolly's Avatar
Default 48 Lectron
Its the whole housing... the stock throttle will not fully open the Lectron slide. The new one has more pull.
Old Aug 14, 2006 | 08:47 PM
DragonDJ11's Avatar
Default 48 Lectron
Being the whole housing makes much more scence. I just was not sure....
Thanks for the super speedy answer...
Old Aug 14, 2006 | 11:37 PM
duneittilludie's Avatar
Default 48 Lectron
Brent are you looking at a 48 for a stock bore or are you considering a big bore?As you have seen my 46 does me quite well and i will only switch if i go to a big bore in the future.
Old Aug 14, 2006 | 11:48 PM
cloftis's Avatar
Default 48 Lectron
I will second that!!!
Old Aug 14, 2006 | 11:54 PM
flyinds's Avatar
Default 48 Lectron
dragon like dune and cloftis said if you are plannig to go with a big bore in the future then get the 48hv if not just get the 46hv but it might not hurt just to get the big carb choose is running a 48hv i believe on a stock bore stock engine. just my 2 cents. good luck on what you do.
Old Aug 15, 2006 | 02:25 PM
choosetolose04's Avatar
Default 48 Lectron
Thats correct. I have been running the 48 on this stock motor for approx 2 yrs without any problem. I do think the nitrous makes a bigger impact (power wise) while running the 48 as opposed to the 46....just a little food for thought.
Hightower
Apr 27, 2004 09:19 PM
918sTaxi
Oct 30, 2002 11:41 AM
QUADLOCO
Sep 11, 2002 01:15 AM
Slobanshee
Feb 22, 2002 10:42 AM
the500bansheepilot
Feb 5, 2002 03:18 PM
