Crank Case Fix ? Can This Be Welded ? Pics.
Here is the atv its a 250 yamaha bruin
think this can be welded or do you guys think itll need to be replaced.
Welding that should work fine, i've seen much bigger holes and cracks repaired by welding and it worked fine. Make sure you get a chassis skid on that thing so it doesn't happen again though, it could be disasterous if that happened and you didn't catch it right away.
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
