Crank Case Fix ? Can This Be Welded ? Pics.
Old Sep 3, 2006 | 03:07 PM
iamsoup's Avatar
Default Crank Case Fix ? Can This Be Welded ? Pics.
Here is the atv its a 250 yamaha bruin
think this can be welded or do you guys think itll need to be replaced.
Old Sep 3, 2006 | 03:49 PM
DuneRider650's Avatar
I ride a little here and there......
are you talking about that little hole? or am i not seeing a crack somewhere.
Old Sep 3, 2006 | 05:15 PM
recon99's Avatar
Welding that should work fine, i've seen much bigger holes and cracks repaired by welding and it worked fine. Make sure you get a chassis skid on that thing so it doesn't happen again though, it could be disasterous if that happened and you didn't catch it right away.
Old Sep 3, 2006 | 06:15 PM
iamsoup's Avatar
thanks, yes i did mean that little hole.
Old Sep 3, 2006 | 06:18 PM
yea that wont be a problem to weld at all
pgamboa
Dec 24, 2023 11:52 AM
QuadRiders
Oct 22, 2015 04:13 PM
bigred20653
Oct 2, 2015 10:05 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
scorpiankill
Sep 10, 2015 09:14 PM
