clutch swap??
Old Dec 9, 2000 | 03:01 PM
weltmaster's Avatar
can someone tell me weather the agressive[hpd] clutch kit out of my 98 sport 400 2wd will work in my new 00 400 scr 4x4?? it is the kit with all the weights,2 springs and different cut helix. all so can you use a roller clutch with that or is it a whole diff set up?? thanks guys!!
Old Dec 10, 2000 | 09:44 PM
weltmaster's Avatar
come on guys!!!
Old Dec 10, 2000 | 09:58 PM
KevinDevitt's Avatar
I am not an expert but I will give you my 2 cents worth. I believe that it will change over with no problem. I just installed the HPD roller clutch and springs and wieghts. You do not see in the catalogs anything that would indicate that there are differant parts for differant machines. Pull it a part and take a look.
KD
Old Dec 10, 2000 | 10:05 PM
Xplor's Avatar
Call Derrel over at HPD and ask him. All I know is the roller clutch replaces the helix, so you will no longer need that.
Good luck
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
